:rotflmao: :rotflmao: :rotflmao: :rotflmao:Steve in Sunny Fla said:I'm kinda heavy,
Steve in Sunny Fla said:they do two different things.
IMO, the emulators are needed to get rid of the brake dive, but still have a compliant "street" ride. Sure you can go with heavier springs or higher oil level, but then it's a harsh ride. On my bike, I have about 5" of stock springs cut off with emulators, works great. I'm kinda heavy, so if you're around 200 - 225, all you'll need is 4" cut from the stockers. HTH, steve
turbojoe78_MA said:Dan, as I am adding emulators now I had received some info from SISF and what he told me to do was go with 4 holes (drill out the other 2) and use the blue springs with 2 turns of preload. This is what he said he has his set up like and say's it works great for him.
GF-in-CA, I would have to disagree, if I could only afford one or the other I would go with the emulators and cut the stock springs down like SISF suggested. I did the cut spring mode before (4" off stock springs) and it worked well at stiffening up the front end and helping with the brake dive for almost no money. The emulators help fine tune it and modernize it from there. JMHO.
danodemotoman said:I didn't read that spacers are being used to replace the stock spring cut spring length?
BTW; my option: I do have the racetech springs/emulators still in the 'old' Conk to use.
I want touring/comfort suspension but not the soft/mushy/dive like stock.
Thanks.
Found emulators on Amazon! Race Tech FEGV S3801. With me being right around 300#is cutting 5"sufficient or would I need to remove more? Is 15W oil ok?Steve in Sunny Fla said:they do two different things.
