Richard_Terry_TX said:Anyone have a list of fastener torque values and willing to share?
Coolsurlasix said:With all due respect to Cap'n Bob and the seniors in this forum, torque value = force * length, for example 97 ft.lb not 97 ft/lb. The longer the wrench, the gigher the torque for the same effort, right?
Richard_Terry_TX said:Need to remove front and rear for new tires, but don't have service manuel yet. don't want to pull them till I know what to retorque to.
thanks
RAMrider said:Richard_Terry_TX said:Need to remove front and rear for new tires, but don't have service manuel yet. don't want to pull them till I know what to retorque to.
thanks
Capn Bob gave you the numbers but I suggest you buy the factory manual. Vs a bmw manual, you don't need to go to factory training. The kawasaki manual is so well written it will make you will feel like a real expert doing any maintenance. It is the best dollar value you will spend to keep your 1400gtr the bike you like so much
ProfessorKonk said:^ Cool,
Are you suggesting a calibrated torque wrench with an 10" handle will deliver a different force at a given setting than a calibrated torque wrench with, say, a 14" handle? If I have 2 wrenches of different lengths, each set for 40 in.lbs., will one deliver more/less "tightening" than the other?
Coolsurlasix said:ProfessorKonk said:^ Cool,
Hi ProfessorKonk,
No. I am just trying to say that Torque = Force X Length, not Force / Length. The longer the arm, the higher the torque on a regular wrench. If you use a torque wrench and two different-length extensions, the wrench will always trigger for the same value, only the force applied will be different. The longer the extension, the smaller the effort for a given torque value, and vice-versa on odd days.
In your example, if you have a distance of 40" between the nut (to be torqued, not yours) and your palm, you need only to apply 1 lb of force to create the 40 in.lb torque (40*1). If the distance is only 20", you would need to apply 2 lb to obtain the same 40 in.lb torque (20*2). Agree ?
