I have a black Cox Radiator Guard for my 2011 GTR1400.
The item# for it is 113-11064. It is specifically for the 2011 model, no range is printed.
Your item# is 113-11059, for 2007-10 models.
However, when I went to the Cox Racing Group site, the item# for mine was listed for "2006-12."
--------------------------- 113-11064.
Year: 2006-12
Make: Kawasaki
Model: GTR1400 Concours
As far as I know, the C14's earliest year was 2007. Strange.
The Cox site segregates the GTR1400 fitment into two groups" 2006-2010 & 2011-2012.
It can get a bit cumbersome with all the different item numbers for guard color, fit year, and model sharing (ZX14).
The 2010 and up have some redesign but I don't think the radiator size changed.
If it did, then the 2010 through 2012 models should all be the same size.
I would think this particular packaging was printed before the 2011s came out, and it should (in theory) fit a 2011-2012.
Was it too big, or too small -- too short, or too tall?
I believe they had redesigned it for the 2011 and added washers. It didn't fit right side to side, then again I'm very particular. I bought an early release 2011 and was told that it would fit the 2011, it didn't.
