I did the overflow tubes in my float bowls and low and behold there is a very slight leak...well a hint of fuel on the drain ends. The garage stinks of gas when I come home for a ride and the wife says I better fix even though the smell subsides in a couple hours. When I did the overflow tubes I did a friction fit by tapping them into place and used J-B Weld as well. On two carbs I drilled through to where the drain screw sits, and on the other two I stopped short, but I don't know which are which. I have an idea what happened. Do you? I'll look into this, this weekend.
