You must have an active membership plan
Use the bottons upper right to Log in or Register for membership - or click here to register to join COG
All new registrations are completed and authenticated using the club's main webpage.
Are the engine bolts metric in the front tip over bar hardware kit? I got some old Rivco bars that came with longer 3/8 bolts to allow mounting the bars but the OEM bolts were10mm metric IIRC.
