You must have an active membership plan
Use the bottons upper right to Log in or Register for membership - or click here to register to join COG
All new registrations are completed and authenticated using the club's main webpage.
So, I was going to pull the coupler, but do not understand how or know the correct method. What will work? Just want to do a little cleaning, inspect & grease. Thanks for your help. frenche
You got the snap ring out, that's a start ;D
It's a pretty close tolerance fit and the rubber dampers (depending how grungy they may or may not be) add some tension. I had a couple of small picks with a 90 degree bend on the end and went in the holes 180 degree's (as much as possible) apart from each other to pull it up evenly.
My $2.00 Harbor Freight pick set is a little light for this job. Making no progress. Pecked coupler very lightly with small ball peen while pulling with pick. Nada. What will break loose?
After cleaning as much crap outta the groove as possible, set a folded up towel on the floor.... then set 4 wood blocks on the floor spaced out around the area the outer rim can sit on, maybe pad those also to prevent marring the rim... then, turn the rim upside down, so the hub faces downwards, and lift the rim and slam it down on the blocks.... gravity will assist, it will eventually pop out....after repetative slams, and choice words being uttered... :rotflmao:
