razorsedge
Scooter
Here's what I've learned after 3k miles with my C14. Perhaps most of you already know this , but I'm going to share this for the new owners. 1. A lot of guys complain about the slack in the rear break. Here's what I learned. It's designed to trail break without setting you on your head. Take the total linked ABS OFF ! and the system will let you use breaking in a more sport bike application. switch it to full ABS and you better be ready for the front end to kick in quick . 2 . Eco mode DOES work if you drive reasonable. If your above 80mph you might as well forget about it . 3. If you think your C14 doesn't have quite enough power to raise the frint end up or leave a rubber streak down the road ? Take your traction control OFF by holding the traction control button till the yellow light stays on on your dash. Then hold on because your going to see a notable power difference. WOW . 4. GO ahead and order some new tires. The factory tires wont get you very far if you really like to ride. Ive got 3800 miles . My back tire is done , and my front is showing wear.
5. Keep the maching in higher RPM's if you don't want shifting problems. I've found coming from a cruiser world, we like to shift in lower RPM's . 6. Last but not least, This is the most amazing maching I ever owned. It's performance level is unbelievable. Get out there and enjoy . :motonoises:
