I finally used my new Morgan Carbtune Pro for the first time yesterday. All I can say is 'Boy, that was easy.' I had some initial difficulty that had nothing to do with the Carbtune but it was remedied on these very forums. I had a hard time getting the vacuum hoses off to connect the Carbtune. The answer was to use needlenose pliers to gently grab the hoses and turn them back and forth and loosen them. After that, they came off easily. The Carbtune Pro has stainless steel rods instead of mercury or another liquid and they're pre-tuned so there's no need to calibrate it. Balancing the carbs took about 10 minutes. The only problem I had is that I was unprepared for the inaccessibility of the middle screw. I finally came up with a solution by using a 1/4" socket extender and a hex screwdriver bit. I replaced the air filter, spark plugs did a valve adjustment prior to the balancing. The improvement in performance was immediately noticeable. I'll report on fuel mileage in a week or so. ::EDIT:: I should also say that I bought a couple of sections of fuel line from the autoparts store and some hose connectors and clamps. This enabled me to use my fuel tank instead of an auxilliary tank.
