Vic_Man_CA
Big Wheel
Hello! I just picked up my first conny. She is an 86 with 62k miles. Runs well, but there are a few problems. -The alternator is not putting out many volts. I dont know if its the Alternator itself or the regulator or rectifier. Either way, the battery goes dead after about 100 miles of riding. Any ideas!? What Volt reading should I be getting and which of the two wires should i test? -The fuel petcock leaks even though the engine is not running. Fuel overflows into the cylinder(#1). So far I like this bike, if only I can stop smelling fuel in my garage! Even when the petcock is in the off position, it still leaks fuel when the tank is near full. I guess it needs a rebuild. I bought this bike for $750 from the 2nd owner. It came with a clean title, current registration, and COMPLETE service history. Everyhting from valve adjustments to oil changes are documented. I replaced the oil, coolant, brake fluid, and did my best to service the bike. Check out my bike. It has potential i think....
