You must have an active membership plan
Use the bottons upper right to Log in or Register for membership - or click here to register to join COG
All new registrations are completed and authenticated using the club's main webpage.
I heard that too. The end of an era. I had a Gen 1, and it is still my opinion that the KLR is a TRUE adventure bike. If you were to find yourself in some far away backwater, a bush mechanic will be more likely able to repair a KLR than a computer controlled BMW/KTM/ETC... I also heard that a KLR could run on questionable gasoline or even coleman camp fuel in a pinch.
Don't get me wrong, pushing me along at 70mph was a chore for this antiquated thumper, but it did great on gravel or well graded fire roads.
I’m not saying you are wrong, but the way I read it is that it is talking about dealer incentives. The sentences both before and after our talking about factory to dealer incentives. The context would suggest that it’s only the incentives that are going away.
There's a substantial thread over on ADVRider about it. The KLR 650 is no longer in production. If Kawasaki will field a replacement remains to be seen.
I talked with my dealer about this a few months ago, he seems to have an inside track (or so one would surmise from his confidence) and he tells me that a version of the klr will be back with a versys 650 engine in it, and that would be GOOD. Steve
