Ok
So I've been working on an idea for a few months now where I want to replace the factory heated grips with a set of Symtec's yet retain the factory heat control. This way I can be free to use whatever set of grips I like rather then be stuck with grip puppies or trying to put murhps grips OVER the stockers. (The stock grips feel just like concrete...Only harder)
So according to the manual, the factory ckt looks like this:
So what I am thinking is connecting the Brown (on the right) and black (On the left) wires from the OEM grips to the red (high) wire of the Symtecs, then the Grey wire from the factory (the ground) to the white earthing wire of the Symtecs.
According to Symtec's site, their grip warmers pull a max of 36 Watts (3A) on the high circuit, However, the problem I am having is that I cannot find out what the spec's on the OEM grip heaters are, I know the heat system itself is fused at 10A so in theory the OEM controller can handle the symtec, but I'd like to go in and confirm before I splice in.
I'd also like to find a source for the connectors that Kawa uses on the OEM grips that way I don't have to splice into the ckt (keep wiring neat, just plug and crash)
What think YE all
What think YE all
