You must have an active membership plan
Use the bottons upper right to Log in or Register for membership - or click here to register to join COG
All new registrations are completed and authenticated using the club's main webpage.
Has anyone tried to mount a pre 94 front fender on a post 94? I’m in the process of designing a naked one, and like the look of the pre- fender a lot better for modifications. I’d love to see pics if you did.
I’ve looked at a few pictures on fleabay and the bolt pattern seems similar, can anyone let me know the spread between the bolts on an pre-94. And then I can measure on my 95?
Yes, this has been done before. I mounted a 1990 fender on a 2005, reusing the bracket/brace from the 94-06 series.
Its been a while but as I recall the bolt holes lined right up. The only issue I was finding slim enough fasteners for inside the fender due to the Gold Wing sized front tire, but I got it to work.
