Hi all. I just rebuilt the frontforks of my 02 Connie with the race tech emulators and springs, along with new bushings and seals. The spring rate is only .8 instead of 1.1 or 1.2 and the oil is 15 wt. The oil is 150 mm from the top. I used the blue spring with 3 pre-load turns and 2 holes drilled in the valve. I'm almost 300 lbs, but I love this set up. The ride over surface irregularities is so much better than stock. The handling of the bike is improved over all speeds.
I know this seems soft based on what I've read on this forum, but I like it. Any issues that I should be worried about with the softer spring? It's still firmer than stock.
Rich
Rich
