If I remember correctly there should be an allen bolt inside the handle bar. Tightening it increases outward pressure to hold the throttle lock in place, while loosening it decreases the outward pressure allowing you to remove the throttle lock.
Shining a light inside the handlebar end should reveal an allen bolt.
