So I'm taking off fairings for valve check. I have Canyon cages. Cut rear middle fairings to be able to remove without removing cages. But I can't get them out? Just can't rotate middle fairing to get it out past cages. On right i know have to remove lower to access timing marks. But with cages, the rubber on bottom of lowers is pretty wedged in. On right I ended up separating the rubber from plastic and leaving rubber in place to get lower off. Then with lower out i was able to get middle fairing off. Can't get left lower off. I haven't tried real hard to get rubber out cause worried i won't be able to get back in. Before going further i have questions. Can you get middle off without removing lower if have cages? What you all are doing to get lowers off if have cages? Separating rubber or pulling it out in tight space between cage, engine and frame?
