Hey all,
Anyone have a solution for replacement sidecase lid gaskets? Opened my left case after a storm and found a pool of water in there. Looks like the lid isn't sealing anymore.
Cheers
Scott
Check and make sure the latches are closing the case fully, BTDT. Easy fix just bend the latching mechanism which is visible when you unlatch the lock.
The left case gets much more work than the right one and there is a visible difference in the condition of the gasket between the two. But I will check the latch. And would still like to replace the 23 year old rubber gasket.
