Ok, so I installed my Mccruise yesterday, (Was way easier then I was expecting)
All was going well, until they had me remove the right side frame brace in order to gain access to the right side cyl vacuum port.
Undo the 2 tight bolts, move the brace and do the job, then go to re-install the brace,,,red loctite per the manual's instruction, rear bolt goes in like butter...front bolt goes in most of the way then gets tight way early...(can still see bolt sticking out) kept turning, and all of a sudden SNAP...freaking bolt snapped off.
I wasn't turning it any harder then I had to in order to get it out and it broke off...GRRRRRR
How hard is this going to be to fix? I hope a drill and an easy out will help, but knowing my luck I'm prob in for a spendy repair
