I was removing the front wheel to replace the tire. With a wrench on each end of the axle, I steadily applied force to release the nut. When the nut on the right side gave way, I heard a crack in the left side. Turned out the speedo gear housing on the hub broke in 3 pieces. The last tire change was done by a dealer so I am wondering if there was something that may have done to weaken the casing. Is there anything I can do to prevent this from happening again when I install the new unit?
