You must have an active membership plan
Use the bottons upper right to Log in or Register for membership - or click here to register to join COG
All new registrations are completed and authenticated using the club's main webpage.
It is just me? After you spend time apart from Connie, when you throw your leg over her the 1st time and pull out of the driveway up the hill.....you get a giddy feeling?
Mirrors folded flat, and a little lean to clear the door jam, and she went right in. I was at a motel that i wasn't comfortable leaving the Connie out overnight. Best part? The front desk guy was watching me roll a motorcycle out of his room.
I had not ridden the DRz in prolly 2 months ... omgosh ... compared to the C14 its was a slug.
when i first took off ... i leaned into it expecting the pull of the C14 ... almost fell onto the tank. :rotflmao:
