I installed my second tire on my 2000 Concours. It took me about 8 hours to get the old tire off of the rim. I was as puzzled as much as anything else, why didn't the experience of doing the front tire last year result in me getting the rear tire dismounted relatively promptly? For a bead breaker, this year I had a seven foot window header and an 8 foot 4x4 post pivoting with a 7/8" allthread link. That worked quickly. I unbolted the rear brake disk, which was pretty hairy because the six allen bolts had been secured with red high strength loctite.
I tried two gadgets for assisting with prying the new tire on the clean rim. The second gadget which helped a lot is a pair of shims, made out of two 8 inch pieces of oak flooring. The motorcycle tire is hard to get on the rim because the outside of the rim is larger than the inside of the tire called the bead. What I figured out is the bead of the tire must be dropped into the root of the rim. The extra 1/2" from being seated in the root is needed so the tire iron can pry the tire bead over the rim edge. To force the tire bead to drop into the root of the rim, I cut two pieces of wood with an 8 1/4" arc. Then I shoved the pieces of wood between the rim and the tire bead. The pieces of wood compress the tire and allow both beads to drop into the root of the rim. It took about an hour to make the shims. With the shims in place, I could start at one end of the shim, slip the rim protector in place, and sort of walk around the rim, levering about 1" of tire bead over the rim edge, and sliding another rim protector in place as I went.
I am not really sure if the idea of getting the bead down into the root really is the key to levering a tire bead over the rim edge. I hope you like looking at the sketch and photo I attach.
For this tire, I bought tire lubricant. If you try making shims, be careful do not let any wood chips get in the rim and bead seat.
