So far, have only worked front rim. Several unsuccessful attempts to break bead. Used improvised lever of 2x6 tubing with pointed 2x4 wood, which was easy once I tried using the bottom side of a truck undercarriage as an end fulcrum.
Several failed attempts mounting one lip at a time. Switched to trashbag method. The first lip went on very easy. But, the second lip was a no go. Improvised by securing top & bottom lips with C-clamps. I wàs at 6 o'clock with a C-clamp at 10 o'clock and the second at 2 o'clock. Easy, peasy, a little over two minutes. Took a little longer to pick the two trash bags out from between the tire & the rim.
Will report on rear tire when available.
