We use the more optimistic phrase "Tip Over Protection" around here, Brian...
You'll find folks out here with a lot of spare parts to trade. There are all sorts of windshields and saddles and mounts and covers sitting around unused in people's garages. But I don't see too many folks with these things just lying around - they tend to stay mounted!
Never fear, Cap'n Bob has been faithfully maintaining the Farkle Vendor Directory which contains the most current info on where to get pretty much anything for Connie and these are no exception:
I have a set of skip holtons rears I'll probably let go, they don't work with my GIVI cases and certainly won't with my aluminum cases.I may ditch the fronts also.
