The left side cover which covers the Dynamo on my 900 is leaking. The grommet the wires go through is known to leak at some point. The fix is a new grommet, cut and re-solder the wires back together after running them through the new grommet. Not my idea of a good time...simple enough but I really don't want to cut wires. So I was thinking of taking the dynamo cover off and hosing everything with brake clean. Then slather the entire grommet/inside wires with Honda Bond and put back together. Or should I just bite the bullet and replace the grommet? If you have not used Honda Bond before it is pretty runny compared to RTV. I know some of you Z1/KZ owners have dealt with this problem. Thanks, Tim
